cadetgubbins@gmail.com |
08-14-2017 06:41 PM |
1991 240 1-2-3, 2-2-4 code
Hey guys I have a problem that im confused about. I have a check engine light and when I pulled the codes I got 1-2-3 and 2-2-4 which are both coolant temp sensors. Now I replaced the coolant temp sensor (the one with 2 prongs not the sensor with one) and I still have the check engine light. I was wondering what else I could do, like check wires from sensor to ecu, or switch ecus from a donor car. Side note when I gas it, it starts to bog down a little bit then will catch back up. Also its a little hard to start now. Not sure what to do and I move away for college in 3 days so I gotta try to finish this quickly, any help is appreciated.
