1991 240 1-2-3, 2-2-4 code
Old Aug 14, 2017 | 06:41 PM
cadetgubbins@gmail.com's Avatar
Default 1991 240 1-2-3, 2-2-4 code
Hey guys I have a problem that im confused about. I have a check engine light and when I pulled the codes I got 1-2-3 and 2-2-4 which are both coolant temp sensors. Now I replaced the coolant temp sensor (the one with 2 prongs not the sensor with one) and I still have the check engine light. I was wondering what else I could do, like check wires from sensor to ecu, or switch ecus from a donor car. Side note when I gas it, it starts to bog down a little bit then will catch back up. Also its a little hard to start now. Not sure what to do and I move away for college in 3 days so I gotta try to finish this quickly, any help is appreciated.
Old Aug 14, 2017 | 07:19 PM
did you clear the codes? those sorts of codes are remembered, you have to clear them, and see if they come back.
Old Aug 14, 2017 | 10:12 PM
Yes I reset the codes, and tried touching the battery cables together and the check engine light still came back on.
SlickBrick
Feb 18, 2017 11:34 PM
Feb 23, 2016 09:08 PM
vipul_vips
Mar 28, 2011 05:29 PM
wakawu
Aug 31, 2010 07:00 AM
repeatclicks
Mar 12, 2006 09:09 AM
