1991 240 3.1 bosch, idle but no acceleration
Ok, here we go. my 1991 volvo 240 wagon has the following problem. i can start the engine in three to four turns of the starter. It will idel normal. no hesitation, no noise, no smoke. the problem is in the acceleration, when hitting the pedal ther is no direct reaction. Whit 3 seconds the rpm's will go up slightly, then it will bog down to idle.
I have replaced the following. new idle air control, new in tank fuel pump, new throttle position sensor, swapped fuel regulator on fuel rail, new fuel filter.
when unplugging the spark plugs and injectors one at a time, engine idles rough. meaning all spark plugs and injectors are hitting. when unhooking the hose from the idle control valve to the hose going ionto the throttle body, engine dies. when unplugging the MAF, engine dies, When unplugging the knock sensor engine dies. when unhooking the air intake pipe you hear the engine suck in all the air, and dies.
this indecates to me the MAF, knock sensor, idle air control all work correct.
I am puzzled by this. it is acting like it is not getting fuel / injectors not speeding up with RPM.
could this be a bad computer????
s/b be jumper 2 for EFI and 6 for ignition.
see Engine and OBD Diagnostic Codes
(LH3.1 is pretty much the same as 2.4)
its ignition off, insert jumper into #2, key on (but not start), press button for over 1 second but not over 3, then release, and it should then slowly blink out a code. 1-1-1 is no errors. if there's any other code, press the button another 1-3 secs, see if there's another code, when the first code repeats you've got them all. key off, move jumper to #6, and repeat.
oof, just looked it up, the LH3.1 cars use a unique MAF, -001, so you can't swap for any 89+ 240/740/940, only with another LH3.1 90-92 240 (and AFAIK, only some 90-92's were LH3.1)
its quite conceivable the new MAF is bad too, depending on where you got it from and who rebuilt it, especially if this was a cheap no-name rebuilder.
but its also possible there's wiring problems, and maybe even an ECU problem.
at this point, I think I'd be inclined to dig out the ECU (its just forward of the passenger door hinge, behind the plastic kick panel to the right of the passenger footwell), and unplug it, and take meter readings of the various sensor circuits connected to it. verify that the idle switch circuit opens when the gas pedal is depressed sligthly, verify the resistance of the engine coolant temp sensor is in range, etc etc.
volvorecycle
Jul 22, 2015 07:44 PM
jxbettis
Sep 14, 2011 06:13 AM
