1991 240 Acceleration hesitation
When I start my 240 up in cold weather, it hesitates first to even start (only turns over) and then continues to hesitate upon acceleration once it does start. Once the car has gone a few blocks and begins to warm up, it drives just fine. What needs to be done to fix this???
Because you have a 91, it doesn't have an OBD-II, but I think there is a diagnostic plug (or the black box), that allows you to see the check engine light flash and essentially give you your cel codes via morse code if you turn your key to pos. 2. I've never owned a pre-96 car, but this is what I've been told works.
There are a set of boxes under the hood. Not sure where but they look like this pic below.
What you have to do is pull the cover off, take the jump wire and plug it into one of the ports, then push the button is a set of functions and the box will flash back the code to you.
1993-1995 Diagnostic Connectors (Check Engine)
https://volvoforums.com/forum/volvo-...1-codes-26676/
http://www.matthewsvolvosite.com/for...hp?f=1&t=36192
I seen a recent write up in the 960 section where people were making a home made OBD-II reader that would flash lights to give codes. Cost about $15 if I'm not mistaken.
Will1147
07-28-2013 02:21 PM
