1991 240 Is my ECU bad
Old Aug 14, 2010 | 05:41 PM
riverdog46's Avatar
Default 1991 240 Is my ECU bad
I recently acquired a 1991 240 and the fuel pump relay won't energize.I have power on the main red wire at the relay and on both orange wires when the ignition switch is on. If I ground the blue-green wire to the ECU the relay closes and the pumps run. I hate to replace an ECU and find out there was something simple like a safety interlock I didn't know about. I can jump out the relay and the car runs fine. Thanks for your help
Old Aug 14, 2010 | 08:21 PM
swiftjustice44's Avatar
Without looking at a schematic, I can't tell you precisely where to look as I've never had this particular problem. I'm sure someone will chime in who has experienced it. I'd say you have a broken, loose or corroded ground somewhere. There isn't an interlock...if it turns out to be the ecu, check eBay as they often are $50 or less.
Old Aug 28, 2011 | 09:41 AM
khelms's Avatar
Im new here I have the exact problem ,I believe its the ecu, let me know I m lost here also.
VolvoBug
Oct 13, 2014 02:44 PM
IrishUpstart
Jan 7, 2013 01:29 PM
dlukowsk
Jun 27, 2012 05:14 PM
91shelby
Jun 20, 2011 06:56 PM
bigern45
Aug 5, 2008 08:14 AM
