1991 240 What is this Vacuum Hose that Goes into the Cabin?
That vacuum line powers the defrost, floor and re-circulation vents. Default with broken vacuum line is floor vents on. It uses vacuum to turn on defrost and recirc. vents.
Easy to replace. 5 minutes working slowly. (can of silicone lube help the hose slide through the grommet in the firewall)
yachts (02-08-2022)
Thanks so much to you and to act1292 for your very helpful and quick replies! Now I am sure we can do this repair right, not just cut off a few inches and attach another tube like my mechanic had suggested because he thought he’d have to remove the whole dashboard or something like that.
Do you happen know, does this hose have an inside diameter of 6.6 mm ?
