1992 240 Vovo AC problem
Old Aug 11, 2016 | 12:59 PM
mjohansson2's Avatar
Default 1992 240 Vovo AC problem
Hello all, I have a '92 volvo 240 that has a bad AC pressure relief valve p/n 6849313 that this part is no longer being made and is out of stock in various where houses I am being told. Have any of you had this problem the valve is bad and leaks, now I could go to a junk yard and get one that may be bad as well, or is there a way to adapt a valve from a different manufacture that would work?
Please let me know.
Thanks. Mike
Old Aug 12, 2016 | 08:30 AM
jagtoes's Avatar
Where is this valve located. Is it part of the hose assembly or located at the compressor. On my 740 they eliminated it where it was on a lower hose assembly.
Old Aug 12, 2016 | 10:56 AM
It is located on a metal line below the radiator/condenser closes to the chassis under the large plastic air deflector.
Old Aug 12, 2016 | 04:44 PM
jagtoes's Avatar
How do you know it is bad. Is it part of the line or can ut be removed/unscrewed.
Old Aug 12, 2016 | 04:58 PM
jagtoes's Avatar
I just looked on line and there are several places that still sell it.
laree
Jan 8, 2016 10:05 AM
Rado001
Jan 10, 2014 03:36 PM
hugostar
Jun 11, 2011 10:12 PM
rich nc
Jan 26, 2010 07:54 PM
mikrin
Jul 1, 2006 09:23 AM
