1993 240 Fix My Running Light or Run From The Cops?
Old Sep 25, 2015 | 11:16 AM
David Ingalls's Avatar
Default 1993 240 Fix My Running Light or Run From The Cops?
So here's where I'm sitting: This summer, my right rear running light decided to go out. I got a warning then forgot about it, so I got a ticket from Yellowstone's finest park ranger... *cough*douchebag*cough*
It wasn't the bulb, and today I thought to switch the wire from the backup (reverse) light to the terminal of the running light, and whaddya know, it worked. SO, that means there is a problem with that individual wire. As far as I can see, there is no problem with the wire, but it runs around the back of the car out of sight to who-knows-where.
If anybody has tips on how to dig out the whole wiring bundle that runs around the rear of the car, that would be helpful. (since it seems to be ridiculously difficult)
In lieu of actually fixing the problem, I was thinking of just rewiring it to something so that it is always on when the car is on. In this situation, what do you think a good system to wire it into would be? I considered wiring it straight to the other running light's terminal, but then I thought that maybe it would be too much current for the wire to handle. If anybody has any experience, input is greatly appreciated. (don't worry, I know my way around a soldering iron and some heat shrink)
Old Sep 25, 2015 | 11:18 AM
REVOLV's Avatar
wagon or sedan?
Old Sep 25, 2015 | 11:24 AM
Wagon
Old Sep 25, 2015 | 11:26 AM
REVOLV's Avatar
do you have 12v going to the bulb socket?
Old Sep 25, 2015 | 11:50 AM
on the 240 sedans, and I'm pretty sure the wagons, the wires all run down the left side door sills, over the left rear wheel well, to the left tail light, then some of them go over to the right tail light.
on our 87 240 sedan, we lost the right rear parking light a long time ago, and yeah, it was the wiring, so I hot-wired it to the left rear parking light. this permanently lit the bulb-out idiot light but that thing was intermittently flakey anyways. had no problems with the wire harness yet, and its been like this for 10+ years.
Old Sep 25, 2015 | 11:54 AM
Thank you pierce! I shall proceed to wire it into the other side's wire.
Old Sep 25, 2015 | 12:20 PM
REVOLV's Avatar
Hey my boss does some quick and dirty fixes like that sometimes. I did it the other day on a Tacoma. Dead cigarette lighter. It would take more time to diag the circuit than just add 12v with igntion on from the disconnected radio wires that were dangling right there.
A wiring diagram and multimeter is the proper way to fix a circuit, but good ol' backwoods engineering can work too!
Old Sep 25, 2015 | 12:35 PM
a cigar lighter needs high current power, they often draw like 8-10 amps, so you need to pull that from something like the accessory power relay rather than directly off the ignition switch.
Old Sep 25, 2015 | 12:38 PM
REVOLV's Avatar
Hey I know the right way and the wrong way to hack stuff in. He will only use it to charge cell phones so it should be OK. If it pulls too much it will pop the radio fuse.
ShowTek
Feb 21, 2012 10:36 AM
trev0006
Nov 23, 2011 06:06 PM
dwaino@live.com
Jan 2, 2011 08:03 AM
theotherpilot
Jul 10, 2009 12:28 AM
Volvorator
Mar 15, 2007 10:37 AM
