1993 240-Headlights don't turn on
Old Jan 19, 2014 | 09:10 PM
Karl Smarkel's Avatar
Default 1993 240-Headlights don't turn on
Alright, I'm hoping someone can provide a bit of insight here. So far I've replaced the headlight switch, the bulb failure sensor, the in-dash main headlight relay, and the step relay under the hood. As added insurance I just put new bulbs in, but I get no voltage at the connection. It doesn't look like any ground wires are loose... All other lights function just dandy. Any suggestions?
Karl
Old Jan 20, 2014 | 03:48 PM
dnarby's Avatar
Clean the ground wires connectors, the ground block, the bolt, and where the bolt mates to the body panel. My 740's both exhibited lots of weird headlight issues (different brightness, ignition cut out when switching to high beams, windshield wipers coming on when turning on headlamps... Seriously, all of those - no joke).
When I cleaned the ground blade, plug and block, all those went away.
I would recommend taking the time to go around all of your connections and clean them, 21 years is a long time to expect unsealed electric connection to remain trouble-free.
jws
Dec 30, 2011 08:09 PM
VDriver24093
Feb 21, 2011 04:35 PM
Typhoon
Jul 11, 2010 10:18 AM
swegyptian
Apr 25, 2010 08:38 AM
rj0828
Jun 14, 2007 03:06 PM
