1993 Volvo 940 wagon - soft brake pedal
Replaced brake hoses, bled brakes at the calipers with a helper pumping the pedal. Didn't see many air bubbles. Pedal is soft and goes to the floor.
Bought a pressure bleeder, bled brakes at 15 lb/inē, then again at 20 lb/inē. Didn't see many air bubbles. The pedal is soft and goes halfway to the floor. What's the secret to getting this right? How much fluid should I expect to run through each caliper to purge all the air out? The pedal was high & firm before replacing the hoses. The pads & rotors are almost new. Single-piston, single hose front brake calipers. Left-hand drive; master cylinder on the left side firewall. ABS on the right fender and a labyrinth of brake piping running hither & yon. https://s20.postimg.org/uqfn8czlp/do...llet-after.jpg https://s20.postimg.org/m2fgxn2v1/940-_ABS.jpg https://s20.postimg.org/536iidrnh/94...r-cylinder.jpg |
