1993 Volvo 940 wagon - soft brake pedal
Old Apr 11, 2017 | 09:59 PM
drcampbell's Avatar
Default 1993 Volvo 940 wagon - soft brake pedal
Replaced brake hoses, bled brakes at the calipers with a helper pumping the pedal. Didn't see many air bubbles. Pedal is soft and goes to the floor.
Bought a pressure bleeder, bled brakes at 15 lb/in², then again at 20 lb/in². Didn't see many air bubbles. The pedal is soft and goes halfway to the floor.
What's the secret to getting this right? How much fluid should I expect to run through each caliper to purge all the air out?
The pedal was high & firm before replacing the hoses. The pads & rotors are almost new.
Single-piston, single hose front brake calipers. Left-hand drive; master cylinder on the left side firewall. ABS on the right fender and a labyrinth of brake piping running hither & yon.
ecberr
Oct 8, 2009 04:54 PM
daver80
Jul 13, 2009 10:25 PM
krs2
May 25, 2009 08:14 AM
cruzcountryxc70
Engine & Internal
Apr 28, 2008 05:42 PM
hosey82
Aug 1, 2007 07:40 PM
