240-740 Wheel compatibility
Old May 11, 2011 | 11:58 AM
300td's Avatar
Default 240-740 Wheel compatibility
I found a set of 14" rims from a 740. I was wondering if they would fit my 1990 240.
factory 14" Volvo wheels
Orginally off 1985-1990 740/760 Volvo's, but may fit other years and models as well..
BOLT PATTERN: 5 x 108mm
Would love to know if they fit!
Thanks!!!!!
Old May 11, 2011 | 03:27 PM
they should fit just fine. 240 sedan used 185/70-14 tires, I believe. wagon might be a size larger. (the 740 probably had significantly wider/larger rubber on it).
do try and verify they are straight. nothing worse than buying some rims then finding out 1-2 of them are bent when they get put on the spin balancer...
Old May 11, 2011 | 07:31 PM
300td's Avatar
Thanks. I will check them as best as I can!
Old May 11, 2011 | 07:49 PM
in a pinch, I've jacked a wheel of my car, taken off that tire, mounted the rim just lightly tightening and spinn it by hand, using a pencil or something held against something stationary as a gauge to compare wobble...... repeat for all 4, then put your wheel back.
35mm
Jun 7, 2012 01:53 AM
jbrown122
Jan 18, 2012 04:44 PM
Burn Stains
Sep 25, 2011 10:03 PM
ltrail
Jul 22, 2010 10:43 PM
klaus
Oct 27, 2009 08:34 PM
