240 Air Con
Where is the suction side port located for recharging the system? How much does the system hold (1988 240)
RE: 240 Air Con
Both ports are on the compressor.
Has it been converted to 134A yet? |
RE: 240 Air Con
It has a leak and I am going to use that enviro 12a. The stuff that is more efficient than r12 safe for the environment and you do not have to change the oil or seals. I learned about it on a search on this forum. I have my yellow glasses and uv light so I can find the source of the leak.
RE: 240 Air Con
RE: 240 Air Con
Let us know how that stuff works. I have always wanted to get first hand knowledge of it. The suction port on my 740 is on the condensor on the firewall passenger side.
RE: 240 Air Con
Since it wasn't converted already then they should be on the compressor on the back side of it.
RE: 240 Air Con
Thanks! When the stuff arrives I will put a little in and see where it is leaking from and go from there.
RE: 240 Air Con
Keep us posted!!
