240 DL Master Cylinder Question
Old Sep 23, 2006 | 09:02 PM
lmyarana's Avatar
Default 240 DL Master Cylinder Question
I replaced the front calipers on my 1988 240 DL, refilled the brake reservoir and started bleeding the brakes. I didn't realize that the reservoir was only full on the front side and that the back side was empty. I had my wife pumping the brakes with no success in getting any kind of pressure and then realized the mistake and filled the reservoir completely. I still can't get any brake pressure even though the reservoir's full and I've bled all 4 wheels three times (there's no air in the system). Is the master cylinder shot? Did I damage it by pumping the brakes with air in the reservoir? I just want to make sure that I really need a master cylinder before I buy one. Any suggestions would be appreciated.
Any website suggestions for buying Volvo parts?
Old Sep 23, 2006 | 11:25 PM
Default RE: 240 DL Master Cylinder Question
If you open the front Bleeders will brake fluid Gravity bleed?
http://www.swedishpartswholesale.com/
Old Sep 26, 2006 | 10:11 PM
lmyarana's Avatar
I checked it and the brakes do gravity bleed.
Old Sep 26, 2006 | 10:26 PM
Sounds funny but are they after market pads?
Try bleeding it at the master cylinder.
Old Sep 30, 2006 | 12:22 PM
lmyarana's Avatar
Yes they're aftermarket pads. I'll try bleeding at the master cylinder.
thanks.
Old Oct 1, 2006 | 09:10 PM
We have had a couple of 240's that had aftermarket pads on them. The brakes feel like yours.
We have bled and tried things for many hours. Still the same. Install a set of OEM pads and brakes are back to Normal.
Dagaan
Sep 21, 2014 12:12 PM
Dagaan
Jul 10, 2014 01:35 PM
Wicksvolvo
Aug 10, 2012 09:11 PM
WagHag
Jan 2, 2007 09:09 PM
suter
Nov 22, 2006 09:13 PM
