240 dying after 10 minutes driving
Old Aug 17, 2008 | 11:22 AM
davidmhuber's Avatar
Default 240 dying after 10 minutes driving
I have a 240 1992, starts and runs great, but only for 10 minutes! After 10 minutes, it dies and will restart once it cools back down, temperature is ok, does not overheat, almost think it might be ignition related, changed ignition coil, yet no effect?
Any ideas?
Old Aug 17, 2008 | 01:26 PM
billofdurham's Avatar
Default RE: 240 dying after 10 minutes driving
Welcome to the forum.
Have you checked for Diagnostic Trouble Codes using the on board diagnostic unit?
Old Aug 17, 2008 | 04:14 PM
not yet, will do tomorrow, will let you know which codes I detect. Thanks
Old Aug 18, 2008 | 08:04 PM
Diagnostic port #6 yield code 2-1-4 which is the speed sensor. Replaced sensor, reset codes, car ran for 45 minutes idling, no trouble codes, will do road test tomorrow, easy fix!
Old Aug 20, 2008 | 12:22 AM
oldskoolsteve's Avatar
I might also suspect in-tank fuel pump.
The in-line will do the job initially but once a heaveir load or longer travel is required the in-line pump overheats and quites untill cooled back down.
An idle test won't reveal this.
Try a good highway drive and hill climb.
marchstarz
Jan 24, 2018 05:39 PM
analogies
Mar 8, 2013 02:21 AM
Bruno937
Aug 23, 2012 07:52 PM
LoLoudnProud
Nov 7, 2009 03:37 PM
cruckster
Nov 19, 2006 07:10 PM
