240 GLT thermostat
240 GLT thermostat
My 1988 Volvo GLT recently developed two faults at once which I thought might be connected: (1) I was constantly having to fill up the coolant reservoir and (2) the temperature gauge needle was constantly below the usual half-way mark (more like one third of the way up the dial). I found that the heater hoses were leaking so I replaced them, which solved problem (1). But the temperature gauge was still reading low, so I replaced the thermostat with a new Volvo thermostat of the same heat rating. I was surprised to find that the temperature gauge is now reading HIGH though still some way from the red zone (about two thirds of the way up the dial). I'd be grateful for any ideas about what I might try next.
Happy New Year everybody, Eric
RE: 240 GLT thermostat
Many thanks for your comments, Tech.
Making sure I "have a good flow" sounds sensible. How do I do it, though?
And when you say that fitting a new thermostat sometimes does result in a higher temperature than previously, are you saying that it's really nothing to worry about?
All the best,
Eric
All the best,
Eric
