240 Hesitating and bogging down
Old May 29, 2008 | 08:50 AM
buzzbomb's Avatar
Default 240 Hesitating and bogging down
Just over the past two days my 93 240 has started bogging down while driving at any speed. At first I thought it was the transmission because it would do that between shifting gears, but the more it happens the engine just sounds like its suffocating, wanting to stall but not quite stalling. It did it this morning coming off a red light and did it lots more on the highway going 70. Any help would be appreciated.
Old May 29, 2008 | 09:18 AM
mikeheraly's Avatar
Default RE: 240 Hesitating and bogging down
Hey buzzbomb, I've been having a very similiar problem with my 1984 240. The problem got progressively worse over time, and I'm still trying to figure it out, but these forums have given me a bunch of advice that have helped a bit. It sounds like a fuel pressure/pump/injection issue, so here are some things you might want to check:
-Fuel filter and main fuel pump
-Prepump and intank filter
-Air mass meter
-Fuel pressure regulator
-Fuel injectors
-and many more...
Let me know if this helps at all, I'm not sure how experienced you are with auto repair (I myself am obviously inexperienced, because I'm still trying to get my car going and have only learned this stuff while trying to fix it recently). But I can give you some tips for checking some of these thingsif you need any. Hopefully some of the other volvo experts of these forums will give you a hand, too. :-) Also...let me know if you figure it out, I could be having the same problem....
Old May 29, 2008 | 12:38 PM
blue goose's Avatar
Check your normal tune-up items -- plug wires, disty cap & rotor, air & fuel filters.
Post back.
Old Jun 9, 2008 | 04:10 PM
bigdaddyrdpjr's Avatar
some may think I am retarded because I say this all the time. I have had 6 240's wagons and sedans including now 1990 240 dl wagon w/ 195000 miles. Change the fuel pressure regulator. several of the ones that I have had have done the same thing and everyime I replaced the regulator it fixed it. $45 from Napa
rb_lifer
Aug 6, 2015 08:15 PM
bullit777
Jun 6, 2014 07:11 PM
Rosew6211
Nov 21, 2010 09:59 AM
Slayder
Aug 2, 2009 05:09 PM
thecarfarm
Apr 15, 2007 02:07 AM
