240 Lower ball joint torque settings
Old Mar 6, 2014 | 04:36 AM
danielp's Avatar
Default 240 Lower ball joint torque settings
Anyone know what the torque settings are for the joint to control arm, nut to plate and 4 bolts to the bottom of the strut. Basically all the torque settings for replacing the ball joint
Thanks you!
Dan
Old Mar 6, 2014 | 05:35 AM
TIPSP's Avatar
Got Boost?
The 4 anchor bolts are ~17ftl-bs
the 3 control arm bolts are ~85ft-lbs
the nut is like 40-50ft-lbs
Old Mar 6, 2014 | 09:13 AM
guest01's Avatar
No that serious, just tighten it.
Old Mar 6, 2014 | 01:18 PM
terrible advice. novice mechanics tend to overtighten small fasteners and undertighten large ones.
Old Mar 6, 2014 | 05:31 PM
danielp's Avatar
Thanks for the advice! very much appreciated
Dan
Old Mar 6, 2014 | 09:31 PM
guest01's Avatar
go ahead and torque every single thing. Will get old real quick. Plus what torque wrench do you own. snap on is the best most accurate torque wrenches. If your using some random wrench you might as well not even torque fasteners.
Old Mar 7, 2014 | 09:12 AM
danielp's Avatar
I don't use a torque wrench on everything. Components that have some importance of allowing the wheel to stay attached to the car I feel that correctly torquing fixings is important.
Over tightening can be just as dangerous as under tightening.
But anyway, I fitted the ball joint today.. Fixing older cars is so much easier than modern ones!
Thanks again for the advice
Dan
dpvovo
Feb 18, 2019 07:41 PM
rileyimport
Dec 16, 2013 09:33 PM
Disco2
Nov 24, 2013 08:25 AM
dejr
May 28, 2013 11:01 AM
volvos8087
Oct 19, 2010 11:16 AM
