240 No Start problem narrowed down SOLVED!!
Old Dec 3, 2007 | 08:07 AM
tngreg's Avatar
Default 240 No Start problem narrowed down SOLVED!!
1991 240
Starting problem had classic signs of Crank position sensor going bad. I changed it and still same issue, but I discovered a new twist.
After trying to start car turns over fine but acts like it's not getting fuel.
I left the key in the ON position and after 1 min. walked to front of car and then heard the fuel pumps run and when I cranked it, it started!
What would cause this lag time in the pumps wanting to run?? With key in ON position after a 30 secs to 1 min I hear fuel pumps run and it will then start?
Please HELP ...THANKS Greg
Solution:
Changed the FP Relay back in Jan. and no problems since....Hope everyone is having a good year!
NOW time to change the Fuel filter.
Old Dec 3, 2007 | 05:13 PM
act1292's Avatar
Default RE: 240 No Start problem narrowed down (I think)....Please HELP.
You might want to check the fuel pump relay. It is located under the dash on the passenger side. Just remove the panel under the dash and there is a gray relay there. It should click as soon as you turn the key on. If it doesn't, give it a whack. You should hear it click. If it does, the car should start.
I had this happen to my '89 wagon. It was intermittant for a year before I was able diagnose the problem
Old Dec 3, 2007 | 05:56 PM
VolvoDriver's Avatar
+1 for the fuel pump relay, also consider replacing fuel filter.
Old Dec 3, 2007 | 06:05 PM
I also agree about the fuel pump relay but it should be white.
birdman_s80
Feb 16, 2015 11:21 AM
abro
Oct 4, 2013 03:50 PM
nybblesandbytes
Feb 15, 2012 03:14 PM
soulcalibur2007
Aug 29, 2011 02:03 PM
likesspace
Jun 18, 2007 09:14 PM
