240 rough idle
Hi there, I have a problem on my 1993 240. The car idles rough when it's cold, it gets better when it,s warmed up, but still not a good idle.
I recently changed rotor, distr. cap, plugs. plugs wires, coil wire and air mass meter.
Any ideas?
Thanks all
Any ideas?
Thanks all
cla665,
I have a 1991 740 and cleaned my IAC,which helped my idle. It is located under the intake about the #3 cyl.,there is one bolt and 2 hose camps to remove. I sprayed mine with carb cleaner with out dismanteling, you can use a scewdriver or stick to open the valve on the end. Hope this helps with yours.
nkinkade
Feb 28, 2014 08:49 PM
dcwave
Nov 27, 2012 09:56 AM
