245 Tailights
Old Aug 23, 2010 | 09:54 AM
darkdelta's Avatar
Default 245 Tailights
I am going to go with LED brake/running lights for my 1990 245. Has anyone done this? If yes, what brand and source did you use for acceptable brightness on brake and running lights.
Thanks in advance
Old Aug 23, 2010 | 11:13 AM
swiftjustice44's Avatar
Default LED tails
On my 89 245, I used drop in 1157 replacement bulbs from superbrightleds.com The actual page is here http://www.superbrightleds.com/cgi-b...rake-turn.html
I bought the 15 led units as anything bigger won't fit through the back of the assembly. Light output is great. In addition, I ganged the top fog lights via jumper wires, to the bottom brake lights, giving me dual brake/taillights on either side. I drilled small holes in the stainless steel socket clips, fed the wires through and soldered them. This avoids the circuit board connections and ensures they stay lit. Because they use less juice and burn cooler than stock lamps, the plastic will not soften and the sockets will never have poor connection. Not that it matters as they are now "hard wired" to the sockets.
Old Aug 24, 2010 | 04:23 PM
darkdelta's Avatar
Thanks for the info Swift, I ordered them today!
kelsodatrini
Jun 15, 2009 06:59 PM
knots
Feb 4, 2008 03:46 PM
thedell
Nov 5, 2007 05:35 PM
s40sightandsound
Sep 26, 2007 12:40 PM
volvobacon
Apr 16, 2005 11:29 AM
