25 amp fuse wiring -83 244
Old Sep 23, 2018 | 09:29 PM
jayg's Avatar
Default 25 amp fuse wiring -83 244
Hi there,
Does anybody have a picture of where the wires going to this fuse are coming and going from?
I have an 83 244 that I bought with no spark or fuel and I've narrowed down at least one of its issue is this fuse. On my car, I have random wires laying over by the fuse holder but nothing is running to it. Furthermore, there is no fuse but a piece of wire jumping the two sides. I planned on getting a waterproof fuse holder but I needed to get an idea of what wires should be running to it.
Thanks
Attached Thumbnails 25 amp fuse wiring -83 244-img_1036.jpg   25 amp fuse wiring -83 244-img_1037.jpg
Old Sep 24, 2018 | 01:29 AM
one end goes directly to the battery, the other end goes to the fuel system relay which is below the glovebox and behind the dashboard, pin 30, at least on the later cars. I don't have diagrams for 81-83
ok, in 84 LH used two relays, and it goes to pin 30 on both of them, as well as pin 86 on the 'main' relay. all red wires. these dual relays are also below the glovebox, side by side.
Old Sep 24, 2018 | 10:59 AM
jayg's Avatar
Pierce,thanks for the reply. In the pictures I typically see, there are two thicker red wires that go to it. I believe I have one here in this harness near the MAF and then the other one would just go to the positive on the battery. I'll get a new 25 amp fuse holder and see what I can come up with. This car has some questionable wiring so I may have multiple issues but at least this one is glaringly obvious and I can get it handled.
Old Sep 25, 2018 | 07:54 PM
jayg's Avatar
Ok a little progress! I got the 25 amp fuse and wired it in to the red power wire for ecu. When I turn the key now, I get a click from the fuel pump relay but when I go to turn it on it still just cranks with no fuel pumps running.
So power is going to the relays now and that is an improvement but no I need to find the next piece in getting spark.
Does anybody know what this larger red wire goes to? It was spliced into a smaller black wire and the under the motor I can see it goes to the larger red wire again.
Old Sep 25, 2018 | 10:40 PM
the timing comes from a hall sensor in the base of the distributor, that provides a (small) impulse for each half turn of the engine... this goes to the ignition control unit, which amplifies adn cleans up the pulse, and forwards the stronger pulse to the ECU for the fuel injection timing. the ICU also calculates how much to advance or retard and sends an ignition signal to the coil to create spark.
Old Sep 26, 2018 | 09:38 AM
jayg's Avatar
It sounds like it's waiting for that signal for sure. I'll look at getting another distributor. Is there a good online parts house for these that people recommend? It's been a while since I've ordered Volvo parts online.
Thanks for the help
Old Sep 26, 2018 | 05:27 PM
I believe the hall sensor plate itself is a seperate part from the distributor.
I got most of my Volvo parts from https://fcpeuro.com, https://ipdusa.com, and for factory only stuff, https://www.tascaparts.com/auto-parts/volvo
Old Sep 27, 2018 | 08:57 PM
jayg's Avatar
I haven't been able to find a hall sensor separately so I think I'll buy a remanned unit shortly.
Thanks for the help on this.
Old Sep 27, 2018 | 10:22 PM
was ognna look up the PN's but there's a million different distributors listed in VADIS, the old parts catalog software.
does your distributor have a vacuum advance module on the side?
if not, and its volvo distributor 1336737, the sensor is 1346803, and wire housing 1346800. ubt, it might be unobtanium nowdays as a seperate part.
Old Sep 28, 2018 | 12:45 AM
jayg's Avatar
If you notice the sketch wiring under the distributor, that may be part of the issue as well but has since been semi fixed. The distributor doesn't appear to have a vacuum advance.
A little background on the car is that I picked it up last week for $180 bucks and I'm trying to get it going for ice racing. Hopefully this year and not next although this car is living outside and it's getting chilly here fast.
Old Sep 28, 2018 | 12:51 AM
whats the number on the side of that distributor after the bosch logo? I can see 0 237 0 but the rest is around the bend
Old Sep 28, 2018 | 03:26 PM
none of that wiring with the tape looks original, its someone's hack.
Old Sep 29, 2018 | 06:48 PM
jayg's Avatar
I attached a better picture of it.
Oh yeah I'm aware.
Old Sep 29, 2018 | 09:00 PM
sa i poked around, couldn't find any parts for the distributor innards. plenty of places selling the whole thing, bosch 0237032001
Old Sep 29, 2018 | 09:24 PM
jayg's Avatar
I bought a remanned unit today so I'll get that a shot in a week or so when it gets here.
Just to recap, currently when I turn the key I get a click from the fuel pump relay but it doesnt run the pump. In theory, once timing is being sensed from the distributor I should have spark and run the pumps when cranking.
Old Sep 29, 2018 | 10:50 PM
first check the voltages on the outputs of the two relays.
1, the main relay, should come on with the ignition key and stay on.
2, the pump relay, should come on for about 1 second then go off til the car is cranked
each relay, the power input to the relay is pin 30, red wire, this should be always hot... if its not hot, then your 25A fuse isn't wired correctly as it goes directly to these two relays
each relay, the power output is pin 87. the main relay powers the ECU and the MAF, while the pump relay powers the fuel pumps, the IAV, and the injectors.
Old Oct 9, 2018 | 12:25 AM
  #17
jayg's Avatar
I dropped in a replacement remanned distributor today and it's the same symptoms.
Key on, click from the fuel pump relay, then no spark or fuel pumps running when cranking over.
Pierce - I just saw your last post and I need to check those relays closer. On an 83, is the main relay and the fuel pump in the glove box area? I can hear a click now after the 25 amp fuse from the glove box area now but I need to dig around and test those relays. Do my symptoms even sound like they could be relay related?
Thanks
Attached Thumbnails 25 amp fuse wiring -83 244-img_1111.jpg   25 amp fuse wiring -83 244-img_1123.jpg
Old Oct 9, 2018 | 12:52 AM
  #18
yes, both those relays are side by side behind/below the glovebox.
Old Oct 11, 2018 | 10:27 PM
  #19
jayg's Avatar
I pulled the relays and I guess I didn't realize they were both the same. Both are old (old enough to be from West Germany) and didn't have the best connections.
I tested for voltage on the black plug and I was getting 12v for pin 30 and that relay was clicking.
The white plug I tested it for voltage with the key on at pin 30 and it was only showing .35v and the relay wasn't clicking. I'm not quite sure if that's normal or not with just the key in the on position for that white plug.
Regardless, I'll buy new non crusty relays since they are cheap enough and I kind of destroyed one pulling it out anyway.
Old Oct 15, 2018 | 09:35 PM
  #20
jayg's Avatar
2 new Bosch relays in place and still no change. Just a click from the relay but no spark or fuel pump running when cranking. Could be wiring, computers... It'll sit for now.
