740 General Stereo Question
Old May 24, 2009 | 10:45 AM
rmmagow's Avatar
Default 740 General Stereo Question
Bought a 91 740 wagon. There's no radio installed. I am thinking to use www.car-parts.com to find the correct replacement (Used) radio/cassette whatever. If the car came with a cassette will a CD equipped head work? Are these radio's theft coded? How do I get the code if the vendor doesn't know it? I had a V70 prior to this car and got lucky, the code was written on the radio. I may well do an upgrade head through Crutchfield but might try a cheap replacement for now.
Thanks Much.
Old May 24, 2009 | 09:31 PM
TIPSP's Avatar
Got Boost?
Good site....Check there or just stop by a local junkyard....
I would just go aftermarket with the headunit....only problem is the slot for the radio is bigger than a single DIN and I believe slightly smaller. I just use a small towel to hold up my headunit. use the stock wire harness to slipce into or make a connect to fit in the stock unit connector.
Old May 25, 2009 | 10:57 AM
tedv's Avatar
Stock radios for the '91 were coded, but the codes can still be had from a Volvo dealer for free. But you need to have the VIN of the car where the radio was originally installed. So, if you get a used one, you will need to know the VIN of the car. Junkyards have these radios (cassettes) and are cheap, especially in the PullYourOwn types. I just got one for $10. As far as replacement, there is an ADAPTER KIT that must be used for a good fit. Stereo shops have them... around $10.
Old May 26, 2009 | 11:53 AM
rmmagow's Avatar
Car turned out to be junk. Hot Ride Motors in PA thieves. See F/S section whole car parts only. Cheap.
Old May 29, 2009 | 05:35 AM
tedv's Avatar
A Volvo, junk? Don't you blaspheme in here!
2004XC90T6AWD
May 26, 2009 08:49 AM
IanCompetent
Dec 8, 2008 11:39 AM
XC9O
Jun 28, 2008 06:58 AM
Aaronius
May 30, 2008 06:10 PM
Daytomann
Sep 19, 2005 09:56 PM
