740 heater/AC air volume issue
Old Sep 5, 2009 | 08:47 PM
jshane1's Avatar
Default 740 heater/AC air volume issue
1989 740 turbo wagon (360K)
Lost air volume to passengers compartment in all control settings.
The fan is working. You can hear the speed change for all 4 steps of fan control.
Air volume from vents very low and does not change as you slide the control slider from position to position.
where is vacuum takeoff from engine to operate vacuum controlled vanes in heater box?
Any other suggestions before i rip console apart??
Thanks
Old Sep 14, 2009 | 11:15 AM
jshane1's Avatar
Default loose vacuum line
I found the problem. The line from the vacuum source in the engine compartment had come loose. The source line goes into the passenger compartment very near the exact center of the firewall. On my car the vacuum source line is protected, and can be identified by, a protective plastic shielding.
ncstatecamp
May 22, 2022 07:32 PM
lafv_5
Apr 30, 2007 05:12 AM
rAcing_VoLvOs
Apr 1, 2007 01:18 AM
zoom18
Jun 6, 2006 01:31 AM
jetmax
May 12, 2006 10:09 PM
