745 tailgate window seal leak
Old May 7, 2011 | 01:42 AM
robdenmick's Avatar
Default 745 tailgate window seal leak
How do you get the outer top window seal off the tailgate window,I have a bead of water running down the inside when it rains, I have tried to get it off but all I can do is move it side to side a few inches then it stops I don't want to force it , Can anybody help me out please?
robdenmick
Old May 7, 2011 | 06:37 AM
Typhoon's Avatar
They're a bonded windscreen. Often the trim becomes bonded in with teh adhesive as it squeezes past the window. I generally just slice the trim off and re apply it with windscreen adhesive, taping it to hold in place till the adhesive seals. Or you can use a fine nozzle and squeeze sealant in behind the moulding.
If you can move it side to side, it's just caught in behind the glass, the moulding has a hook shape to it that holds it in behind teh glass. It should come with persuasion, just start at one end and gently pry it out with a wooden stick or similar.
Old May 8, 2011 | 02:57 AM
robdenmick's Avatar
Hi Typhoon, sorry its taken this long, managed to get trim off put some more sealent on clipped the trim back on good as new, thanks for the advice
robdenmick.
Gregman
Aug 1, 2011 11:14 AM
moosepucky
Aug 6, 2008 04:37 PM
scott k
Aug 5, 2008 05:49 PM
BriGuy
Mar 20, 2008 08:32 PM
Typhoon
Jan 2, 2008 01:01 AM
