79 245 temp reports hot in cluster when engine cold
Old Jul 2, 2008 | 09:16 PM
d0u6's Avatar
Default 79 245 temp reports hot in cluster when engine cold
my 1979 245 this week started out with some hesitation during acceleration and today the instrument cluster temperature gauge says its hot with the engine off and completely cool.
im not sure where to begin, every one keeps suggestion different things but arent familair with volvos.
suggestions? thanks!!
Old Jul 3, 2008 | 11:45 AM
wojeepster's Avatar
Default RE: 79 245 temp reports hot in cluster when engine cold
volvos have a 'temperature compensation board' designed to keep the needle in the center unless it really overheats. If this board goes bad you get the result you are seeing. Instead of replacing the board it is possible to remove the board and insert a small jumper wire then your gage will display actual temperature! IPD had a kit and directions for how to do this. It is not the reason your volvo is running poorly as there are two temp senders and the one for the gage is separate from the other, so I think you have another totally different problem.
wisgolf
Jan 11, 2014 06:33 AM
GSXV50
Nov 8, 2011 08:22 AM
chellebelle393
Apr 7, 2011 05:46 AM
beardo265
Sep 27, 2007 09:24 AM
