87 240
Old Nov 17, 2007 | 06:08 PM
mamali's Avatar
Default 87 240
Hi just bought an 87 240 5 speed. It was sitting for over a year. Most of the tail lights do not work. I have checked the fuses and the bulbs and they are fine. Any thoughts?? ANy help will be appreciated. Thanks
Old Nov 17, 2007 | 06:27 PM
yeravgjoe's Avatar
Default RE: 87 240
We're having the same issue with our '86 240DL sedan. We've replaced all of the light bulb holders, we're thinking of replacing the circuit board next. Does anyone have any smart ways of troubleshooting to determine what the problem might be? A friend suggested that a wire or relay under the dash might be the cause of our problem. The "bulb out" light on the dash goes on whenever I press the brake pedal, and it also goes on when I turn on the headlights. The fog lights seem to work, but the brake lights do not. Any ideas?
Old Nov 17, 2007 | 06:33 PM
mamali's Avatar
Default RE: 87 240
Is there one fog light or 2? On the rear. Mine has similar issues. Reverse lights work, brakes do not. When I turn on the head light only one side works!! I get the bulb out light as well when I turn on the head lights.
Old Nov 17, 2007 | 06:55 PM
Default RE: 87 240
Only 1 foglight.
Inspect the plastic where the socket locks into to. They are known to melt or fall apart.
The circuit boards are also known to go bad.
If the plastic is broke in any way buy a new light assembly.
If the plastic is all good buy new circuit boards.
Also if you buy new parts STAY AWAY FROM SCAN TECH. They are junk.
Old Dec 1, 2007 | 12:36 PM
CTR's Avatar
CTR
Default RE: 87 240
I have an '87 245 DLand I hada similarproblem except there was a short and the fuse blew on a regular basis. The auto shop couldn't figure out what was causing the short and after a couple of hours of trying to see where a wire was cutI noticed the wire running through the hinge on the roof was cut. I put some heatshrink on it and ran a wire from theside brake light to the center one. Now it hasn't blow in a few months.
insectintellect
Jul 5, 2012 01:49 PM
dman777
Aug 7, 2009 03:19 AM
bne
Apr 6, 2008 05:12 PM
maves75
Feb 3, 2008 04:56 AM
1985_240DL
Sep 20, 2006 08:20 PM
