87 240 temp gauge
Old May 20, 2009 | 11:11 PM
buddyvol's Avatar
Default 87 240 temp gauge
The temp gauge is not working on my 87 240 There seems to be 3 or 4 what look like temp sensors on the engine. which one is the one that makes the temp hand on the instrument panel work? fuel gauge only works sometimes also. Any answers?
Old May 21, 2009 | 11:54 AM
blue goose's Avatar
There is a 10-volt stabilizer, a silicone-controlled rectifier, at the rear of the instrument cluster. It controls the operating voltage to the temperature and fuel gauges. The voltage out of that SCR should be between 9.8V-10.2V. You can check it fairly easily with a multimeter by pulling the instrument cluster part way out.
Post back if you need further guidance on how to pull the cluster.
cc sbrider
Sep 27, 2014 03:16 AM
AnEskimo
Mar 7, 2014 08:29 PM
blackbrick
May 7, 2011 01:46 PM
vcolper
Nov 1, 2006 10:20 PM
