88 740GL horn selectively not work
Old Dec 3, 2010 | 08:00 PM
calvinhoe's Avatar
Talking 88 740GL horn selectively not work
My horn selectively not work. Is there a slip ring that grounds the steering wheel, allowing the horn to be grounded and thus honk? My VW has the same issue and cleaning the slip ring, the horn worked.
Thanks
Old Dec 3, 2010 | 10:00 PM
swiftjustice44's Avatar
No because it has 2 thumb contacts on the wheel to activate the horn. There is a spade terminal that is visible when you pull the wheel. Sometimes it corrodes but more often it is a loose or corroded ground wire near the horns.
Old Dec 5, 2010 | 06:56 PM
calvinhoe's Avatar
Talking now to remove the steering wheel
I remember all the warnings about the airbag so DISCONNECT the battery negative first.
Where do I go from there? I note that there are two screws holding the crowling immediately behind the steering wheel. Some guidance would help here. Thanks
Old Dec 6, 2010 | 09:57 PM
lev's Avatar
lev
there are 2 torx screws holding the bag in on the lower side. u have to turn the wheel, may be 45 deg's to clear the housing. believe, the tool size is t20-has to be a long skinny one, socket won't work...
Old Dec 6, 2010 | 10:00 PM
lev's Avatar
lev
btw, u don't nec. have to take out the wheel, in airbag cars u'll see some of the horn wires once the bag is out. if you do have to take out the st. wheel, lock the clock spring or you'll break it and it runs like $300... careful!
MNWILD
Jan 7, 2011 07:59 AM
buellfire
Jun 20, 2009 12:37 AM
KESchumacher
Apr 18, 2006 08:33 PM
gur8
Aug 14, 2005 12:46 PM
Tecno88
Feb 10, 2004 01:14 AM
