89 240dl stalls after start up
Old 08-11-2005 | 02:19 PM
oscar moncada's Avatar
Default 89 240dl stalls after start up
hi. recently bought a 89 240 with 120000 miles. failed emmisions too lean. last month car wont stay running. unplugged maf sensor and stays running. tried a used maf same problem ck fuel pressure ok grounds ok cleaned tb no vacum leaks possible ecu ? any help will be apreciated thanks.
Old 08-11-2005 | 05:23 PM
Ignavus's Avatar
Default RE: 89 240dl stalls after start up
Try cleaning the idle air control valve and replacing the intake manifold gasket.
Old 08-11-2005 | 10:55 PM
Clean the throttle body and idle motor first then if you still have the problem move to the intake gasket.
Old 08-16-2005 | 05:17 PM
hello again. replaced intake gasket and cleaned idler valve same results will not stay running unplugged maf and stays running what do you suggest i should do next. thank you for taking the time to help me.
Old 08-16-2005 | 05:27 PM
Ignavus's Avatar
Check the connections and wiring connector plug at the AMM ( maf) for corrosion , look closely and make sure the small metal contacts in the AMM plug are in good shape and are able to make a secure connection . If you still have the same results with a known good AMM, the it would be time to try another ECU.
Old 08-21-2005 | 02:15 AM
matthewensey's Avatar
I have an 88 240, and I was having an overall power problem with the car. Stalling after idle was surely involved. After changing the plugs and wires, it was better, but still there. Naturally, I moved onto the distributor cap and rotor, 30 bucks together from Autozone. When I was changing them, I noticed that the distributor was loose. There is a slotted bolt hole that keeps the distributor in line with the engine timing. That bolt had worked its way out, or someone hadn't tightened it after servicing before I bought it. I simply adjusted that slowly with trial and error until the car ran MUCH BETTER. I double checked myself with a timing light the next day, and I was dead on. That solved my problem. With the MAF giving you hell, my advice might be unhelpful for you, but, if the timing were off like mine, having the MAF functioning would seriously throw off the Air/Fuel Ratio with the bad timing, possibly enough to cause a stall.
Old 08-31-2005 | 01:23 PM
hi. have not try the ecu yet shopping for a used one in abay. however, i have a question concerning a 740 and v70. the 740 i repleced the headgasket but now the ck engine light keeps comming on code 143 would yuo please tell me whats code 143. the v70 i replaced the a/c evaporator after a few days later the compressor runs all the time i replaced the a/c ciclyng switch with no luck could it be the evap temp sensor if so where it is located not very sure. thanks again for all your help. will keep you posted
Old 08-31-2005 | 07:53 PM
Ignavus's Avatar
Assuming that the 740 has the Rex-Regina engine managment system, then code 143 is a problem with the knock sensor.There is no 143 code for LH2.2 or 2.4 equipped cars listed in my book.
Old 08-31-2005 | 10:21 PM
Yes that is a knock sensor code.
The A/C on the V70 does it freeze up or just run alot?
Old 09-01-2005 | 10:28 AM
hi again back to my 240. the problem was a wrong amm 007. i installed an amm ending 016 and i made the differnce the car runs great and does not stall. thanks again. sometimes the junk yard doesnt work all that great. going back and see if they can exchange it for the wright one will see. back to the v70. both lines going to the evap are freezing up. must turn compressor on and off to prevente this. it is very cold inside. is the switch i replaced the same as the evap temp sensor? not very sure. and thanks again. the 740 i cleared the code has not back yet will keep you posted.
Old 09-01-2005 | 09:41 PM
What year is the V70?
If it is older than 2001 than the low pressure switch is bad located in the lines by the firewall.
If it is a 2001 or newer I would try to replace the evap. temp sensor.It should be located in the side of the air box on the drivers side.(U.S. drivers side)
jessierose
03-25-2014 12:30 AM
240DLighted
05-01-2013 01:55 PM
miss ammo
07-26-2011 10:52 PM
rainman14624
09-20-2010 10:22 PM
soapboxhero
09-02-2006 08:26 PM
