89 740 GL starts and idles fine until warm.
Old Sep 27, 2020 | 12:22 AM
Gary62's Avatar
Default 89 740 GL starts and idles fine until warm.
Then idles speed +-750 rpm climbs to about 1400 rpm. Has new rotor and dist. New plug wires and iridium plugs. New fuel pressure control valve. New IAC, brake booster and maf. Runs great other than the fast idle and it's a little bit harder to start when warm... Engine temp sensor maybe? Any help appreciated. Thanks
Old Sep 27, 2020 | 11:35 AM
Goldenblock's Avatar
Default 740
Change/ adjust/ replace your throttle position sensor!!!
Old Sep 27, 2020 | 01:14 PM
Gary62's Avatar
OK. Ordered. Should be here next week. Will advise. Thank you.
Old Sep 27, 2020 | 06:44 PM
i would have tested it, its a simple switch, closed when the throttle is at idle, open otherwise.
Old Oct 3, 2020 | 10:14 PM
Gary62's Avatar
Smile
Thanks Goldenblock. Replaced TPS and its running smooth. No RPM change from idle. With 350000 km, now its ready for another 350000! Thanks again.
Old Oct 4, 2020 | 10:58 AM
Default 740
Your welcome!! Sometimes people over compensate with too many words to diagnose.... Glad its doing well
Gary62
Sep 27, 2020 12:21 AM
jagtoes
Aug 14, 2018 01:42 PM
Ryan911t
Dec 13, 2017 12:59 PM
lagwagin
Nov 4, 2007 01:34 AM
moogman
Jun 8, 2005 12:48 PM
