'89 740 Power sunroof
Old Jun 24, 2005 | 04:23 PM
digitizzle's Avatar
Default '89 740 Power sunroof
I just recently bought an 89 740 Turbo that needs a few hopefully minor repairs. The main thing I'm concerned about is the sunroof motor assembly. The power sunroof will open with the switch, but I have to close it manually with a screwdriver. Is it the switch that needs to be replaced or is it the motor assembly itself?
I was also wondering that if it was the motor assembly that needed to be replaced, if I could replace it with a manual assembly which costs a hell of a lot less.
Any answers or info will be much appreciated.
Old Jun 24, 2005 | 11:09 PM
Carbuff's Avatar
Default RE: '89 740 Power sunroof
The sunroof switch is a known weak point. Start by cleaning or replacing it.
Instructions here
http://www.brickboard.com/FAQ/700-90...gSunroofSwitch
Once disassembled you will find that there are two sets of rotating rocker contacts inside. Small pitted areas will be evident on a few of them.
I used 1500 grit sandpaper to clean the contacts and applied the smallest amount of conductive grease before reassembly. Mine works fine now.
Old Jun 25, 2005 | 11:53 AM
I agree clean the switch first.
Old Jun 25, 2005 | 09:30 PM
digitizzle's Avatar
Thanks for the info.
meburt02
Jul 3, 2012 09:56 AM
davidschaffer
May 29, 2010 04:48 PM
angusmacg
Dec 29, 2007 02:19 PM
elderzap
Nov 7, 2007 04:58 PM
volvofamily
Sep 15, 2007 07:32 AM
