'91 240 Auto-trans Leaks
Old Mar 29, 2005 | 05:50 PM
mktmkt's Avatar
Default '91 240 Auto-trans Leaks
After a head gasket job, auto trans leaks fluid from top to bottom of the transmission area. The leak is not from the transmission pan/gasket. Shop said not caused by their job and don't know what causes it. Any suggestion?
Old Mar 29, 2005 | 09:40 PM
Default RE: '91 240 Auto-trans Leaks
The front seal on the trans could be leaking.The tailshaft could be leaking.There is also o-rings behind the fittings where the trans line bolt to the trans.They leak somethimes.
Old Mar 31, 2005 | 12:20 PM
mktmkt's Avatar
When we shift on reverse there is some kind of chattering noise. Hoist the car up, see the shift link (only on reverse) hit the rotating shaft making that noise.
The cause is the broken axle mount that sag the AT and cause the front seal leak. Case close. And thanks again.
Old Mar 31, 2005 | 02:38 PM
Your welcome glad you got it fixed.
nortons
Feb 22, 2015 11:14 PM
VolPat
Jun 15, 2012 08:06 PM
Barnacle Bill
Feb 27, 2011 05:22 PM
jpirish
Mar 26, 2010 03:16 PM
repeatclicks
Sep 3, 2007 07:57 PM
