'92 240 - Turns Over, Won't Start
Old Jul 28, 2012 | 02:41 AM
N.B. Lynch's Avatar
Default '92 240 - Turns Over, Won't Start
This evening, driving at 60ish mph, I lose power in the accelerator. Car slowly and steadily decelerates until it dies altogether. No hiccups, no sputter, just dead. Engine turns over, but won't start at all. Nothing. Tow it home.
New battery, new spark plug wires, new fuel pump, new fuel filter, new fuel pump relay, new fuel pump fuses, newish mass airflow sensor.
Only other problem I've had recently is I have to pump the gas when I start the car in order to keep it from immediately dying.
Thoughts?
Old Jul 28, 2012 | 01:46 PM
N.B. Lynch's Avatar
Good spark from ignition coil wire.
Old Jul 28, 2012 | 03:50 PM
well, on a no start, the first thing to do is determine if its spark or fuel. crank it a few times, then pull a sparkplug or two. if the plug(s) are wet, you aren't getting spark. if they are dry, you aren't getting fuel (and the spark is unknown, there's stuff that does both).
If you have a timing light, clip it on a spark plug lead, and crank it over and see if the light flashes, if it does, you probably have spark.
if no spark AND no fuel, start looking at things common to both, like the hall sensor in the distributor and its wiring.
Old Jul 29, 2012 | 03:02 AM
N.B. Lynch's Avatar
Turned out to be broken timing belt. Opening it up tomorrow for repairs.
Old Jul 29, 2012 | 03:06 AM
aahhhhh, that will stop ya in the tracks, too! oops. at least these are non-interference engines, except the B234F DOHC/16V version.
Old Jul 30, 2012 | 01:58 PM
N.B. Lynch's Avatar
I disemboweled the 240, replaced the timing belt, got it all running.
My only concern is the crankshaft pulley bolt. I've tightened it as much as I can with sharp jerks of the breaker bar, trying to put as much brief, concentrated pressure on it as possible. Did about 8 or so complete turns of the pulley in this way, so it's on there pretty good.
But I understand that a loose crankshaft bolt can screw things up pretty bad, so my question is:
How much tighter does the bolt need to be and is there a way for me to do it without an impact wrench or jamming stuff into the flywheel? Or, God forbid, is it ok as is?
Old Jul 30, 2012 | 02:21 PM
my bentley book says 44 ft-lbs plus an additional 1/6th turn.
what you did sounds excessive, like in the 100 ft-lb+ range... but I guess that depends on the length of your breaker bar. I would have used a torque wrench.
Old Jul 31, 2012 | 09:55 AM
N.B. Lynch's Avatar
The breaker bar was about 18 inches, and I hadn't found a way to lock the pulley down, so it was still turning with the bar...that said, you really think I managed to put that much torque on the bolt?
Old Jul 31, 2012 | 10:17 AM
well, torque is pounds times feet. so how much force do you think you put on that 18" lever? multiply by ~ 1.5 to get ft-lbs.
Old Jul 31, 2012 | 11:52 AM
N.B. Lynch's Avatar
Tough to say. A moderate amount of force, but I don't have any point of reference for how much that would be. Plus the pulley is absorbing some of it into its turn.
Old Jul 31, 2012 | 11:57 AM
I looked, but sadly, the bentley book I have doesn't seem to give any clues on how you're supposed to immobilize the pulley or crank.
Old Jul 31, 2012 | 11:58 AM
N.B. Lynch's Avatar
So, yeah, more than enough to turn the crankshaft, at any rate.
Old Jul 31, 2012 | 12:05 PM
N.B. Lynch's Avatar
Oops, cross posted.
Thanks for checking. Appreciate that.
Old Aug 1, 2012 | 07:25 AM
act1292's Avatar
I doubt that you have the bolt torqued down properly if you weren't able to immobilize the crankshaft. IPD sells a tool for immoblizing the crankshaft for torquing the crank pulley bolt but I have never used it. Search the forum here for the "rope trick". I haven't used this method either but it basically involves snaking rope into one of the cylinders. This keeps the piston from reaching TDC and immobilizes the crank. Just make sure that the cylinder is in the firing position (both valves closed).
Good luck.
Old Aug 1, 2012 | 02:11 PM
N.B. Lynch's Avatar
Chain wrench braced against water pump, torque wrench with a cheater bar. Voila.
Old Apr 10, 2022 | 03:26 AM
digital.mick's Avatar
Tool is main option , remove front belt cover. Easiest job.
Tighten to finger tight plus quarter turn ONLY. No heavier turning.
Make certain the harmonic balancer is properly flat against the engine.
Jerry Balch
1998-2000 model year XC70
Feb 15, 2014 11:51 PM
spike1962
Apr 25, 2008 06:56 PM
hitwriter
Mar 20, 2008 03:03 PM
Volvorator
Sep 21, 2005 10:22 PM
