92 940 1-2-2 Code
Old 10-21-2021 | 08:32 PM
drvolvoturbo's Avatar
Default 92 940 1-2-2 Code
Hey all, been having idling issues after cleaning my throttle body. Prior to cleaning the throttle body, the car would stall, rarely, but sometimes the idle would go so low the car would want to die out. I cleaned the throttle body, then began having a high idle, around 1500rpms. When the car was driven for about 10 minutes, the idle would stabilize, so I figured the computer was relearning. About two hundred miles later, the problem has worsened. However, today the 940 threw the check engine light. I checked it out and got the 1-2-2 code. According to volvoclub, the code means, "Signal missing or faulty to/from air temperature sensor - Air temperature sensor." Has anyone had the air temp sensor go out on them? Could there be underlying issues here? I'm hoping that this is all that's wrong, and plan on replacing it soon.
Old 10-25-2021 | 01:14 PM
Goldenblock's Avatar
Default Air temp
I ve never seen one go bad ever!!!! Check the wiring to it.
regarding the throttle body... I ve never cleaned mine ever car us 35 yesrs old. So your problen could be the wiring.
Swapping inva new or used 1 takes 20 seconds.
If you need one i have plenty!!!
Goldenblock
Old 10-26-2021 | 11:50 AM
If you have a regina car, there is an air temp sensor in the air intake hose near the air filter. If you have a bosch fuel injection system the air temp sensor is part of the air mass meter.
Old 10-27-2021 | 04:10 PM
Goldenblock
Thank you for your advice! I removed the sensor from the housing, cleaned it out and the light went away. Upon installation, the car's idle was even worse then before. I realized that there were three vacuum leaks and changed those hoses out. The idle has improved significantly. I assume that prior to me cleaning the throttle body, the car had compensated for those vacuum leaks and I hadn't noticed it until after. All in all, the car is running fine so far.
Old 10-27-2021 | 04:17 PM
Thank you, I have a regina car and used one of the service manuals I have to find it. I cleaned the part and the light went off; I cleared the codes after.
lifeofgold
09-11-2016 11:14 PM
240nc
02-28-2015 02:33 PM
ms000
01-02-2015 11:15 AM
twntink
10-16-2007 04:16 PM
zmontgomery
01-26-2007 08:45 PM
Quick Reply: 92 940 1-2-2 Code
