volvo 940 poor MPG, uneven idle when cold
Old Jan 2, 2015 | 12:57 AM
ms000's Avatar
Default volvo 940 poor MPG, uneven idle when cold
I am trying to diagnose the problem with volvo 940 wagon ('93). It has uneven idle when cold (rpm fluctuates for about +-250 and car vibrates). Also, combined fuel consumption averages to unreasonably low 14-15 MPG.
Recent work done includes replacement of spark plugs wires, cleaning crankcase ventilation, checking vacuum hoses, and oxygen sensor. Any suggestions on where to look would be appreciated.
Old Jan 2, 2015 | 11:15 AM
act1292's Avatar
Poor mileage can be caused by a failing engine coolant temperature sensor - the one used by the ECU (not the temp gauge). It can be tested using an ohm meter. Check it prior to replacing. Here is a link to a description of how to test it:
https://www.brickboard.com/FAQ/700-9...eratureSensors
Exhaust leaks upstream of the oxygen sensor can also reduce your mileage. These leaks let oxygen into the exhaust stream causing the ECU to think the engine is running lean and enrich the mixture.
As far as the low idle - check/clean your throttle body and idle air controller. Then make sure the throttle position sensor and throttle body is adjusted properly
turbo940v
Nov 13, 2010 11:27 PM
wilsdon82
Jul 4, 2008 06:37 PM
JohnB
Oct 28, 2007 12:30 AM
postdoc99
Feb 8, 2007 08:00 PM
trhillar
Oct 18, 2005 09:32 PM
