92 940 GL no spark..
Old Apr 22, 2012 | 12:50 AM
RunEddie's Avatar
Default 92 940 GL no spark..
HI im new to this forum. well I bought a 92 940 gl 2.3 non turbo from a friend for 100 bucks ( yeah i know a steal!) She took it to work one day and when she came out it would not start. so i bought it and towed it home. there is no spark at the coil so i bought a new coil along with the module that goes below it. still no spark. the blue wire is getting 12.6 volts. any ideals thank in advance!
Old Apr 22, 2012 | 04:18 AM
sicnarf's Avatar
Change the crankshaft sensor wire as this is bad so you dont get a signal to the databox which in turn sends a signal to the engine firing.It lies between motor and gear box at the back of the motor.Very easy to change.
Old Apr 22, 2012 | 06:49 PM
ed7's Avatar
ed7
+1 on crank sensor.
After that, check power stage (ignition module). Crank sensor is reasonable new, grab a module at the salvage yard.
Get a Haynes manual.
Ed
Old Apr 22, 2012 | 11:44 PM
RunEddie's Avatar
That was it thanx guys!
volvoQ's
Apr 23, 2011 10:00 PM
futbolfan15
Apr 2, 2010 09:56 PM
rooster11
Jul 19, 2009 03:03 AM
bacardi
Jun 16, 2007 07:06 AM
