92 940 shakes and rattles under hard acceleration
Old Jan 2, 2013 | 01:12 PM
92_240_sedan's Avatar
Default 92 940 shakes and rattles under hard acceleration
I have noticed that whenever I accelerate quickly my sorta shakes and groans and vibrates from the rear.
I topped off my differential fluid and changed my transmission fluid.
should I be concerned?
Old Jan 2, 2013 | 08:37 PM
Burn Stains's Avatar
The car will give feedback on hard acceleration, your differential might be getting worn out, but probably will never give out. As for the shaking, how are all your bushings?
Old Jan 2, 2013 | 09:40 PM
check the driveshaft center bearing too. its in a rubber waffle support, that hardens and cracks, then the drive shaft can rattle around under heavy load.
worn rear suspension bushings can do this, too.
Old Jan 5, 2013 | 08:10 PM
swiftjustice44's Avatar
Along with the above, worn motor mounts and transmission mounts will mis-align the entire drive shaft.
jcjcrespo
Nov 11, 2014 10:02 AM
brf0007
Nov 8, 2010 11:35 AM
audiobiz
Mar 8, 2008 05:06 PM
jerryman
May 23, 2006 01:19 AM
