93 240 no spark no start
Old Sep 29, 2010 | 09:45 PM
mickmike1980's Avatar
Default 93 240 no spark no start
Hello all,
I have a 93 240 2.3 and she won't start. It died while driving very suddenly and that was that. I checked for fuel and it is being delivered so then I checked the coil. Spark was weak so I replaced it. It started twice, I drove about a mile and where I parked is where it remains. I am now getting no spark off the coil wire but the coil has power to it. I pulled the cap and rotor to check points but alas there are none. Is there a cam position sensor on this car, if so where the heck is it! My chilton talks and shows a lot about 940 models but neglects my poor 240. Please help me!
Old Sep 30, 2010 | 06:26 AM
act1292's Avatar
There is a crank position sensor that sits on top of the bell housing where the engine & transmission are mated. The wires on it tend to get frayed and corroded. If this sensor isn't working, you won't get any spark. Check this wire. Wiggle it and see if it starts. If it does, then it's time for a replacement.
Good luck.
Old Sep 30, 2010 | 11:56 AM
Great I'll check it right now. Thanks
Mike
Old Sep 30, 2010 | 12:08 PM
Ghost Brick's Avatar
If the wire on the crank position sensor has a yellow stripe (they may have stopped using these by 93) replace it anyway. The newer Volvo ones have a white stripe.
Old Oct 1, 2010 | 12:04 PM
bigdaddyrdpjr's Avatar
As far as the stripe goes, I just put a crank sensor on my 91 940 and the was not any color on the wire (1 week ago). Also the Radio Interference Suppression Relay. It controls the power to the fuel injection. Mine went bad too. Not sure exactly where it is on the 240. Under the hood on the driver side I think.
Old Oct 1, 2010 | 01:53 PM
Well, I pulled the crank sensor and the insulation has melted and I can see copper on one of the wires, so I've got a new one coming today. The one bolt that held it on to the car was one of the more challenging bolts I've had the pleasure to remove. They sure tucked that one in there.
Old Oct 2, 2010 | 10:27 AM
Church Bassist's Avatar
Does your model also have that power stage integrated circuit on the left front inside fender ?
Old Oct 2, 2010 | 12:05 PM
Yes on the driver side wheel well but I put the new crank sensor in and BINGO!!! She starts right up and even idles at a more regular speed that before she broke down. Thanks for the help everyone!!!
Mike
Old Jul 21, 2016 | 05:44 PM
Japess's Avatar
Default Alternator mis wire volvo 240 DL B23
Hello all,
I have a 1984 240 2.3 and she won't start. It died while driving very suddenly and that was that. I checked for fuel and it is being delivered so then I checked the coil. I am now getting no spark off the coil wire but the coil has power to it. I pulled the cap and rotor to check points but alas there are none. all dash instruments stop working too... I did smell burning rubber..Please help me!
email japess@gmail.com
Thanks in advance
volvoQ's
Apr 23, 2011 10:00 PM
futbolfan15
Apr 2, 2010 09:56 PM
iatotofts
Mar 17, 2010 06:50 AM
dldunckel
Jan 20, 2010 07:02 PM
