94 940 help with ac parts
Old Jun 9, 2015 | 09:44 AM
Geogeek18's Avatar
Default 94 940 help with ac parts
I have a 1994 Volvo 940 base with Rex Regina and I need the three valve stems from the lower passengers side of the ac condenser. I put a new ac condenser in and they come with a European sized valve stem not the U.S. Size. Wel at least that's what Nissens told me. Ac works great but the switches don't go on far enough to depress the schraeder valve so they 1) won't control the fans and 2) the high pressure cut out won't shut the ac compressor off. Tried drilling out the old low speed fan switch to fit but the o-rings don't deal properly. I can only run the ac on the highway. Any help would be appreciated.
Thanks
Dave
Old Jun 10, 2015 | 01:29 PM
greenman86's Avatar
Are you sure you ordered the correct ac condenser? It seems old that the valve stems are not correct. My next question, are these valve stems removable? Did you keep the old ac condenser?
Old Jun 10, 2015 | 08:11 PM
Geogeek18's Avatar
Thanks for the response. The Problem has been resolved. Found a 960 in the junk yard and pulled them out and they are the correct ones.
T77911S
Jun 28, 2018 02:18 PM
Iamdagerman
Mar 4, 2013 12:27 PM
TacklaNHL
Jul 29, 2012 11:20 PM
sbirchfield
Sep 24, 2011 06:52 PM
andrew123
Canada, Over Seas & Elsewhere
Jan 9, 2011 05:09 PM
