94' 940 Turbo Wagon Idle speed seems low
My 94 940 turbo wagon seems like it has a low idle .. it never stalls so perhaps it is just me thinking it is lower then normal ....
In Park warm it is at 650 maybe 700 ... reading on the tach on dash In drive it seems to be be right at 500 I have check - no vac leaks I have cleaned throttle body and air motor checked all air ducts new air filter installed sprayed carb cleaner around intake gasket .. no change in idle what is the normal idle speed in park and drive??? Thanks for any help |
Does it idle smoothly? Throttle response nice? If yes, why worry? Lower idle is better if there are no other side effects... Idle may be should be a little higher, 750-800, but who cares? If you still want to raise it, do it at the throttle linkage--there is a little screw, need to loosen the 8mm nut to make it turn using a small thin flat head blade.
