940 locking problems
I have a 1992 940 GL, the problem is, i just changed the trunk lock(key didn't work) so it work a lil, then the lock hinge came off(from the cylender to the latch). My central locking system doesn't work. now I need help with gettin in.Plz help...
It's simple to open...takes some time...but the process is simple. Using the rear seat ski hole is indeed what you use. BUT you need a ratchet with LOTS of extensions to reach the lock bolts. I think they are 10mm. Midgets are good...but quite expensive.
