940 no start need help got fire to the plugs got fuel got weak injector pulse checked
Old Jun 26, 2019 | 08:03 AM
Ken Johnson's Avatar
Default 940 no start need help got fire to the plugs got fuel got weak injector pulse checked
Got spark fuel weak noid on injectors timing belt good compression 150psi 165psi 160psi 165psi so what could it be put new engine speed sensor new fuel pump in tank and fuel pump relay
Old Jun 26, 2019 | 02:35 PM
is this a turbo? and what year? there's some variations on how the injectors are powered, but generally, the juice comes from the 'radio suppression relay' on the left fender, which is turned on with ignition, and if its a turbo, there's series 'load resistors' before the injectors... the ECU 'grounds' the injectors to fire them, one output, all 4 injectors fire at the same time, twice per ignition cycle.
Old Jun 26, 2019 | 09:44 PM
Default 1993 940 turbocharged
Old Jun 26, 2019 | 10:07 PM
so, battery -> RSR -> load resistors -> injectors hot side.
injectors other side -> ECU
Old Jun 27, 2019 | 06:24 PM
Default Pierce
[QUOTE=pierce;474897]so, battery -> RSR -> load resistors -> injectors hot side.
> ECU[/QUOTE
I got 10 to 11 volts at the injectors batterys at 12.2 volts
Old Jul 6, 2019 | 01:15 PM
12.2 volts is way too low. a fully charged lead acid battery at rest with no load should be about 12.6V ... 12.2 is nearly 50% discharged.
Old Jul 11, 2019 | 03:53 PM
Default Pierce
Pierce help me out with this volvo its pissing me off i put a cap and rotor on it still no start; rotor Ω 1152 Ω checked all grounds battery at 12.8 volts got the exhaust discounted not a flow problem
Old Jul 11, 2019 | 04:00 PM
insufficient information to even begin to guess whats wrong.
atwolfe10
Nov 6, 2016 03:18 PM
saabvolvotech
Jan 3, 2014 02:57 PM
Tony Villa
Oct 4, 2012 06:31 PM
tdrendel
Feb 25, 2012 09:31 AM
djslimfm
Feb 14, 2011 04:22 PM
