940 transmission fluid
I would like to know what is the recommended transmission fluid for a 94 940 non turbo and how many quarts does it take, thanks.
For fluid type/quality read this:
https://volvoforums.com/forum/volvo-...f-types-54087/ As for quantity, if you're just draining the pan from the plug pick up a gallon and you should have an extra quart... If you're flushing then you'll need as much as you want to flush through. |
