940 Tweeters
Old Jun 2, 2024 | 04:28 PM
oli_9012's Avatar
Default 940 Tweeters
Thinking about replacing the dashboard tweeters in my base 940. Anyone know where the crossover point is for them and how to get those speaker grills off without damaging them?
Old Jun 6, 2024 | 08:02 PM
admasters's Avatar
Removing the grille is easy, pop off the plastic bezel closest to you and then with a small screwdriver or pick, pop up the rivets that hold it into the dashcap. The entire speaker assembly will now come out.
Now for the hard part, the tweeters are hard wired to the stereo and the door speakers run through the amplifier, and the twain shall never meet.
If you are replacing the headunit, then it is no problem, just trace the wires. I installed CerwinVega 3" tweeters in my car (after cuttiing out the old tweeters) but also had to cut into the vent duct directly below it to create enough space. If you try a direct replacement, the impedence of the speakers will not be matched to the stereo, IIRC they are 8ohm speakers and most modern speakers are 4ohms.
I have a set of known-good tweeters, PM if you'd like to buy them
Old Aug 24, 2024 | 04:11 PM
oli_9012's Avatar
Thanks man, sorry for the late response forgot to check my account. The car had an aftermarket headunit installed long before my time so I guess the wiring is anyone's guess. I'd imagine they must be in parallel with one of the other speakers because the stereo only has 4 channels and the crossover is inside the tweeter assembly?
Old Aug 24, 2024 | 07:39 PM
oli_9012's Avatar
Checked and yeah it looks like the tweeters are driven in parallel with the front door speakers and the crossover is a tiny capacitor inside the tweeter module. Appreciate the advice the tweeters came out no problem.
Ty Jessop
Jul 11, 2021 12:51 AM
gibbogti
Nov 18, 2015 12:41 PM
KSIMP88
Dec 23, 2006 08:23 PM
mbaker
Oct 21, 2005 08:48 PM
