Air direction
Old Sep 26, 2007 | 11:01 PM
bigdaddyrdpjr's Avatar
Default Air direction
my 89 240 dl wagon only blows through the floor and the vents. If you close all the vents and cover the floor vents w/ you hands it wil blow through the defrost but hard to drive that way..... Any thoughts???
Old Sep 26, 2007 | 11:42 PM
83242GT's Avatar
Default RE: Air direction
try checking to make sure you have plenty of vacume to the controlls, if not i think they default to the floor and side vents at least thats what mine did.
~John
Old Oct 11, 2007 | 09:59 PM
I am getting ready to pull this thing apart and see what I got. Any advice????
Old Oct 11, 2007 | 11:06 PM
funnyguy44444's Avatar
The floor, defroster and recirc buttons are all vacuum controlled. There are 2 valves that control the floor vents. One is directly behind the glove box and the other is directly behind the instrument cluster (It can be accessed from beneth but the easiest way to get to it is to pop the instrument cluster out). they are easily removed because they are just pieces in the air ducts that snap onto the adjoining pieces on either side (Kind of hard to explain but if you just take a look you will see what i'm talking about). The valves for the defrosters are under the dash more towards the center but close to the floor valves. If they all are not working though my bet is that one of the vacuum hoses came undone. check those first. each valve should have a vacuum hose hooked to it. If those are all good then check the switches to see if there is a leak there. Good Luck.
Old Oct 12, 2007 | 01:15 PM
blue goose's Avatar
Here are some pics from cleanflametrap.com in case you haven't seen them.
http://cleanflametrap.com/a_man/
Old Oct 13, 2007 | 04:23 PM
tripleb's Avatar
Most systems default to the defrost for safety reasons. This one may or may not, I'm not sure.
Check the vacuum supply hoses in the engine compartment that go into the firewall, one may be split or broken.
Old Oct 13, 2007 | 09:47 PM
Thanks all! Going to tear into it in the next day or so and I will let you know what happens.
Mddsteve
Dec 3, 2013 02:20 PM
Psaboic
Aug 1, 2009 11:23 PM
sofob0909
Jul 17, 2009 08:18 PM
Branan
Dec 8, 2005 09:15 PM
Colin Carter
Oct 3, 2005 10:09 PM
