Airbox woes, no start, no boost.
Old Apr 25, 2016 | 05:18 PM
ConkersBadBreath's Avatar
Question Airbox woes, no start, no boost.
*1984 Volvo 245 GLT*
Hey guys, I posted months ago about an exhaust leak and a no boost symptom. I fixed the exhaust leak, but when I go to start, Im not getting a good fire.
Before I started work, I noticed I wouldnt make any boost and that the car was running rich.
Symptoms are as follows:
No start, engine might fire for a second, then die immediately.
When I attempt to start, the air box occasionally makes a very loud pop sound, like a backfire.
plunger sticks inside the airbox, and is drenched in oil.
Im running acceptable compression on all cylinders 105-110 psi across the board.
Should I attempt to take the airbox out and clean every part individually?
Old Apr 26, 2016 | 08:30 AM
first question that came to my mind was how did the oil get into the airbox? (PCV /flame trap issues?) If there is oil in the intake path then you'd want to clean the idle air valve, throttle body, boots/tubes etc (not sure if your 84 uses a similar plunger metering plate as my 84 Audi had but you don't want that to be sticky... just thinking if you need to remove to clean or can clean top down by removing the boot)
Old Apr 26, 2016 | 11:28 AM
Nichals's Avatar
toasted turbo? among other things
clean it up, put t back together, and if there is oil in the airbag the MAF might be killed
Wait do 84's have MAF sensors?
Old Apr 26, 2016 | 04:41 PM
Makes sense Im just gonna go ahead and clean it. Turbo is in fine condition. I took a look at it when I pulled the exhaust manifold, no play in the fins, wasnt spilling oil all over the place. Just gonna sop up the puddle and clean it out best I can.
97black850
Mar 31, 2014 04:27 PM
endneu913
Mar 28, 2010 11:41 PM
ldsafety
Jul 5, 2008 04:11 PM
Typhoon
Dec 17, 2007 03:18 AM
JBVolvo
Apr 23, 2007 01:04 AM
