Alternator is not charging!!!
Old 06-26-2007 | 04:53 PM
gobaer7's Avatar
Default Alternator is not charging!!!
Hello,
I recenty had to replace my atlernator for my 1987 volvo 240. Since then it has not been charging, I am on my 4th atlernator b/c I kept going back for another when I tested it to find that it wasnt charging on my car. With my current atlternator I tested it b/f I put it on my car like all the others b/f and it was charging but when I put it on my car it does not charge. I then took the alternator off and went back to test the alternator and it passed the test. We checked all wiring that goes to the alternator and made sure no positive wires were laying against any metal and insulated it. All wiring that goes to the alternator has continuity as we have already tested for it. Any suggestions would be a big help...just had to buy another battery b/c I killed my last one.
Thanks
Old 06-26-2007 | 09:54 PM
wojeepster's Avatar
Default RE: Alternator is not charging!!!
if your charge light on dash is burnt out alternator will not charge. When you turn the key to 'on' it should come on. This wire supplies the initial 12v to get the alternator charging, once alternator starts charging light goes out because there is 12v on both sides of light and no ground.
Old 06-26-2007 | 10:26 PM
You are 100% sure the wire is good at the harness plug at the firewall?
I also agree with above about the light bulb.
Old 06-28-2007 | 06:00 PM
gobaer7's Avatar
Well my charge light comes on when I turn the car on
Old 06-28-2007 | 06:02 PM
gobaer7's Avatar
Tech, When you say the harness plug are you referring to the engine wiring harness plug?
Old 06-28-2007 | 06:42 PM
ORIGINAL: gobaer7
Yes thats what I mean.
Old 06-30-2007 | 10:37 AM
gobaer7's Avatar
Okay is there a specific wire that you are talking about or the wiring harness plug in general?
Old 06-30-2007 | 11:03 AM
I forget the color for the Alt. trigger.
Thats the one I would try replacing.
Old 06-30-2007 | 11:47 PM
gobaer7's Avatar
Would it be red by any chance, I know theres a small red and black wire that connects to my Alt. that goes into my harness I believe...
Old 06-30-2007 | 11:50 PM
Maybe my wiring diagrams don't go that far back.
Old 07-01-2007 | 03:54 PM
Boricuaguy18's Avatar
checkall urwires and that u have a female connector connected on the altenator
jessealanramsey
03-24-2023 01:39 PM
primolee
01-24-2014 11:55 AM
timster
01-20-2014 06:31 PM
rahman20k
12-20-2013 08:59 PM
Melvin Lindbergh
07-20-2009 11:44 AM
