Alternator weirdness
Old Apr 28, 2008 | 10:17 PM
merphant's Avatar
Default Alternator weirdness
So I got an oil change and the monkeys there busted off the field wire to the alternator. So now the battery doesn't charge. Simple fix, right? Just reattach the wire. Well, no, that didn't work. I'm reading about 8 volts from the negative battery terminal to the binding post on the alternator. The B+ cable is fine; 12 volts to ground, same as the battery. Sometimes it works to run a jumper wire from the positive battery terminal to the post on the alternator; it spins up and starts putting out 14 volts. But lately it doesn't. Any thoughts? I am thinking maybe it's a bad voltage regulator.... ? I actually have a spare alternator I can put on, but I don't want to kill that one by installing it into a bad electrical system. Any light someone can shed on this would be appreciated.
Old Apr 29, 2008 | 12:24 AM
jonesg's Avatar
Default RE: Alternator weirdness
You didn't say what yr or model.
On my 740 its simple to pull the regulator and brushes to check for wear.
i installed the internal adjustable regulator with brushes from Barton's.
http://davebarton.com/AdjustableVoltage.html
Old Apr 30, 2008 | 09:12 PM
merphant's Avatar
Oops sorry. It's a 1989 240 wagon. I'll examine the regulator; does it sound like that might be the problem?
Thanks,
Sam
Old Apr 30, 2008 | 11:16 PM
jonesg's Avatar
I've read the voltage usually goes high when the regulator dies, low voltage sounds like brushes.
2 screws and they're out.
reneweteling
Jun 12, 2011 05:06 AM
schrodingerscat
Oct 17, 2010 10:51 AM
Luger
Sep 14, 2010 10:16 PM
jodyMXH
Jan 7, 2009 04:56 PM
kannegaard
Aug 16, 2006 08:37 PM
