B-230F fuel Injectors - Correct Type????
Old Jun 9, 2023 | 07:28 PM
abro's Avatar
Default B-230F fuel Injectors - Correct Type????
Hi and Hello:
I am curious and stomped. I ordered (4) BOSCH p/n 0 280 158 045 Fuel Injectors from IPDUSA, all black in color. IPD says "they are an upgrade to" the yellow top China made p/n 280150762 Fuel Injectors and will work in my application. The yellow top injectors have a wider shoulder compared to the BOSCH and fit tightly into the manifold. The O-rings are wider also and help create a tight fit at the discharge and fuel inlet ends. The BOSCH injector has smaller-rings and is somewhat "loose" in the manifold. If I start the car, I am sure of a gas leak. This is not good.
Who has experience with injectors? Keep the yellow type or use the BOSCH? Something is wrong. The yellow are a fraction of the cost of the BOSCH on Ebay.
Thx. Engine is B-230F. One of my injectors has high ohms reading so I thought I would install all new (total 4) injectors. Car only has 135k miles, low gas mileage, good compassion all 4 cylinders so lots of life left in the car.
Comments, thoughts??? I think I will stay with the yellow top injectors.....right?
Thx. long live DL-240 VOLVOs
91-740Turbo
Feb 9, 2014 08:45 PM
tdrendel
Feb 25, 2012 09:31 AM
VJZ
Jan 28, 2009 01:29 AM
cranky
Oct 26, 2005 12:25 AM
lleroyb
Oct 12, 2005 10:57 PM
